Engine System Fault Plus Other Issues
106,000 MILES • 1.6L • FWD • AUTOMATIC
ISHRAF
I have a automatic 2006 ford focus ghia 1.6.
Sometimes the engine wont start unless the ignition is turned numerous time and almost every symbol comes up on the screen or I just sit and wait and I see the "P" on screen and then it starts ok. At other times it works fine first time.
Also, while driving, the speedometer sometimes doesnt work, and messages such as reduced acceleration and engine system fault shows up along with all the symbols such as 'abs', 'immobiliser light', 'engine oil', 'airbag' etc. And the car jerks a little and then again at times these go away.
I took it to a garage and they said the ECU board was damaged and water has got into it. Can this affect the starting of the car? And will replacing the ECU fix the problem?
Many thanks for any advice given.
Apr 14, 2014 at 7:23 AM
  • 31,937 POSTS
A Faulty ECU can do this, but further investigations do need to be made to prove the point, the ECU can be tested and if there is water stains on it or in it, this must be fixed first.
Apr 20, 2014 at 10:59 AM
