Engine swap and different flywheel
2007 MITSUBISHI LANCER
120,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
LARRY NASON
  • 48 POSTS
Doing an engine swap on the car listed above, the replacement motor was used and preferred online. The flywheel that was on the old motor looks like a dual mass but on the replacement motor the flywheel is not a dual mass. Am I going to have any issues using the flywheel, pressure plate and clutch plate from the old motor one the replacement?
Feb 18, 2022 at 2:18 AM
  • 110,194 POSTS
If it is the same engine, there should be no problem. The original one should go right on. Are you using a direct fit engine or are you changing size?
Feb 18, 2022 at 9:09 PM
LARRY NASON
  • 48 POSTS
It's the same engine.
Feb 19, 2022 at 7:39 AM
  • 110,194 POSTS
Larry,
Since it's the same, I don't feel you will have any issues. However, let me know if there is anything I can do to help.
Feb 19, 2022 at 11:57 AM
