Engine swap
180,000 MILES
RICH BRAUN
Is it possible to swap a distributor motor for an electronic ignition motor. Both are Pontiac 2L 1993 motor into a 1990 Sunbird?
Apr 23, 2016 at 8:33 AM
SATURNTECH9
  • 30,869 POSTS
The problem being is the different computer engine wiring harness and possibly the engine itself being different.
Apr 23, 2016 at 8:53 AM
RICH BRAUN
The engines look identical except for the distributor and coil. Could I possibly convert the newer motor by swapping coils and distributor.its an overhead cam and the distributor is horizontal off the end of the cam shaft. There is a cover plate where the distributor would be.
Apr 23, 2016 at 9:42 AM
SATURNTECH9
  • 30,869 POSTS
How is the engine harness not going to be different? Now you have a coil pack and crankshaft position sensor to plug in? Also the computer has to be different with the different wires? Hope you see what I am talking about now?
Apr 23, 2016 at 10:09 AM
SATURNTECH9
  • 30,869 POSTS
Also whats size motor is it? Give me that information and I have a source that should tell me if the engine will work.
Apr 23, 2016 at 10:10 AM
RICH BRAUN
i have a 1990 Sunbird convertible with a motor plagued with problems. It has a 2L turbo. The car I found on Craig's list is a 1993 2L. Both are overhead cams. By what you are saying it sounds like I am biting off more than I can chew! Maybe I should keep looking.
Apr 23, 2016 at 10:19 AM
SATURNTECH9
  • 30,869 POSTS
I tried to look up the years and models engines that fit your car and it does not list them for your car on my information.
Apr 23, 2016 at 1:52 PM
RICH BRAUN
Thanks very much for trying, saved me from more grief than I already have. I may try to fix this one, temperature gun shows me 250+ degrees at one bearing real not the camshaft while the ones next to it are a 100 degrees cooler. Probably means a new camshaft and a warped head. To top it all off GM has pretty much discontinued everything. I will keep an eye out for a similar motor. At least I can still drive it out of my driveway. So I can get my bike out. CHEERS!
Apr 23, 2016 at 2:20 PM
