engine swap
2003 FORD
94,000 MILES • 4.6L • V8 • RWD • AUTOMATIC
PETE ROCK
Was told an 05 crown vic engine would work in my 03 vic n bolt up to trans with no problem. Is this true?
Mar 19, 2017 at 4:19 AM
HMAC300
  • 48,601 POSTS
it should only difference would be if one were stick and other automatic. they are both 4.6L
Mar 19, 2017 at 4:49 AM
STEVE W.
  • 15,411 POSTS
Should be a drop in, just check if you have or don't have an engine oil cooler first. You may need a few extra pieces that are much easier to install with the engine out.
Mar 19, 2017 at 12:28 PM
