Engine swap
216,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
PANDA4920
I have a 1999 Accord four cylinder that I wanted to switch with a 1996 Accord four cylinder. will that work?
Jun 17, 2019 at 3:54 AM
  • 55,711 POSTS
They had many different styles of engine do they look the same have the same part number? If you call a wrecking yard they can tell you because they have special software they use for compatibility issues. Please let us know if you need anything else to get the problem fixed.
Jun 18, 2019 at 11:54 AM
