I have a 1999 Accord four cylinder that I wanted to switch with a 1996 Accord four cylinder. will that work?
Jun 17, 2019 at 3:54 AM
✓Experienced Mechanic
They had many different styles of engine do they look the same have the same part number? If you call a wrecking yard they can tell you because they have special software they use for compatibility issues. Please let us know if you need anything else to get the problem fixed.
