Engine swap
2013 CHEVROLET CRUZE
160,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
LUCIANO DEAL
A mechanic swaped a 1.4 turbo engine out of a 2013 Chevy Cruze and installed a 1.8 non turbo. can this setup work and can the ECU be programmed to work with the 1.8?
Mar 28, 2020 at 11:08 PM
Good morning,
No, you need the ECM for the 1.8 and also the harness. The harness is different as well.
Does the car run?
Mar 28, 2020 at 11:33 PM
LUCIANO DEAL
Yes, the harness and fuse box was changed, but when we hook up 1.8 ECU it doesn't power on with engine light but if we connect the 1.4 ecu it powers on.
Mar 29, 2020 at 12:24 AM
The 1.4 was programmed to your car.
The 1.8 is not and must be programmed to your car in order to work.
That needs to be done by a shop that can do programming or a dealer.
Mar 29, 2020 at 12:29 AM
LUCIANO DEAL
So it will work once programmed?
Mar 29, 2020 at 1:19 AM
It depends. Some ECM will not take a reprogram when one is already installed. Some of them do.
I have had both situations. I always recommend replacing with rebuilt or new but economics get in the way and I understand that.
The simple answer is yes, but remember, it may not work depending on how it is programmed.
Mar 29, 2020 at 1:25 AM
LUCIANO DEAL
Okay, thanks a lot.
Mar 29, 2020 at 6:53 AM
You are welcome.
Always glad to help.
Mar 29, 2020 at 7:01 AM
