Engine swap
150,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
MECANICO3
  • 32 POSTS
Can I install an OHV engine instead of regular OHC engine in this truck? Any ideas or procedures are welcome. If possible what and what do I need?
Oct 10, 2018 at 2:21 AM
  • 110,251 POSTS
Anything can be done, but to what extent are you willing to go? Honestly, it can be done, but everything needs changed. By that, I am referring to the electrical system/wiring harnesses, ignition system, computer, engine vacuum system. The list goes on. It will turn into a nightmare. If I recall correctly, the exhaust manifolds are different and will not bolt up to your factory system.
As far as directions, there is not anything written for this type of procedure.
Let me know if you have specific questions.
Oct 10, 2018 at 11:36 AM
MECANICO3
  • 32 POSTS
Thanks for reply. I just hate this crap of an engine (ohc).
Oct 10, 2018 at 9:46 PM
  • 110,251 POSTS
Welcome back. I understand. Actually, the older ones with the 5.0 ran the best, but they stopped making them.
Oct 11, 2018 at 9:44 AM
