Engine swap
175,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MROBINSONCONTACT
I have the car listed above Concours. head gasket is allowing exhaust into coolant. Car is really a beauty and was looking to do an engine swap, versus a repair as its cheaper if not the same price. Was wondering if anyone could give a list of compatibles.
Mar 20, 2020 at 9:40 AM
Good evening,
The 4.6 engine is your only option and there are plenty of them out there.
I would go to www.car-part.com. They will give you pages of options.
Mar 20, 2020 at 10:10 AM
This would be quite a feat to change to a different engine. However, there should be plenty of 4.6L available because it was put in a lot of different vehicles. I would just find locate a 4.6L or have the head gasket repaired. It may be cheaper depending on where you had it priced, I would suggest having a few more estimates done just to make sure because I am not sure just a head gasket would be more expensive then replacing the entire engine. There are cases when this is true but not sure this is one of them.
Mar 20, 2020 at 10:20 AM
