Engine swap?
170,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
LARRYDIRK
I Have 2005 Ford Ranger with a 3 liter engine - automatic Tran, can I replace the engine with an engine from a 2007 Ford Ranger 3 liter engine - standard Tran (would keep the automatic tran)?? If the engine will fit/work, will the automatic tran fit/work on the 2007 engine?? Thanks
Apr 26, 2026 at 7:26 AM
STEVE W.
  • 15,385 POSTS
The engines do not interchange between 2005 and 2007. 2004, 2005 and 2006 will interchange but the 07-08 engine is different enough that they won't fit the older vehicles.
Apr 27, 2026 at 10:17 AM
