Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
3
Engine
Replace/Remove
Engine swap
2008 MAZDA 3
188,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
CCROMER
MEMBER
1 POST
Can a 2005 Mazda 3 2.3l engine be swapped out and put into a 2008 Mazda 3 2.3l? They are both manual.
Nov 26, 2019 at 12:16 AM
Experienced Mechanic
Good evening,
The simple answer is yes, they can.
You may have to make some changes to be sure everything from the old motor is transferred to the donor motor. Check both engines carefully.
According to the engine manuals, they are the same block.
Nov 26, 2019 at 8:24 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
