Engine swap
2008 MAZDA 3
188,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
CCROMER
Can a 2005 Mazda 3 2.3l engine be swapped out and put into a 2008 Mazda 3 2.3l? They are both manual.
Nov 26, 2019 at 12:16 AM
Good evening,
The simple answer is yes, they can.
You may have to make some changes to be sure everything from the old motor is transferred to the donor motor. Check both engines carefully.
According to the engine manuals, they are the same block.
Nov 26, 2019 at 8:24 AM
