engine swap 5.4L triton?
240,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
WYO_307
Hi, i have a 2001 f250 that need the engine replaced. i was given a 5.4L triton and its from a 2004, can i transfer the 2001 intake manifold, throttle body and other engine parts to the 2004 engine? or will i need to replace things like the fuel lines, fuel pump, fuel injector rail and some electrical parts. Thanks, Ethan
Nov 20, 2025 at 12:22 AM
  • 55,649 POSTS
Yes, you can use the 2004 5.4L Triton long block in your 2001 F-250 IF you transfer all of your 2001 top-end and front accessories onto the 2004 engine.
The long-block (block + heads + rotating assembly) is compatible.
BUT:
Intake manifold
Throttle body
Fuel rail
Injectors
Coils
Wiring harness
Front dress (alternator/brackets)
Exhaust manifolds
…must all come from the 2001 engine.
Here is the video series that can help you will the job.
https://www.youtube.com/playlist?list=PLe3kz1i_LrtW3ODDMG4vIXMXmRDgKE1D5
No need to replace fuel lines or fuel pump. The 2004 fuel system will work with the 2001 truck as long as you use the 2001 fuel rail + injectors.
Let us know if you need anything else.
Nov 21, 2025 at 2:21 AM
