Transmission issues after engine swap?
68,000 MILES • 2WD • AUTOMATIC
M KONG
If you do an engine swap what would cause the transmission or what would cause the car not to want to engage in driving after you replace it with another engine or after an engine swap what would cause the transmission to lose power.
Oct 23, 2024 at 6:59 PM
  • 55,710 POSTS
If the torque converter is not seated correctly when you bolt the engine up it will damage the front fluid pump of the transmission and will need to be repaired. This video will should you what I am talking about:
https://www.youtube.com/watch?v=ZC7xHVMKLRw
Let us know what you find.
Oct 24, 2024 at 3:49 AM
