Engine surging only when it is at operating temperature
98,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JAMES SNIVELY
  • 7 POSTS
Hello, I am having a problem that i cannot figure out. I have noticed a decrease in mileage also. My engine surges when the car is up to operating temperature. Mainly at lower speeds. It causes the car to "buck". I have replaced the air filter, fuel filter, and spark plugs and it still has not fixed the problem. It doesn't do it when cold. It seems the longer you drive the car the worse it gets. Stumped!
Jun 25, 2022 at 12:09 PM
  • 110,251 POSTS
When this happens, have you ever noticed any dark gray or black smoke from the exhaust? I ask because the coolant temperature sensor may not be working properly. Info from the sensor is used by the computer to determine the air/fuel mixture needed to run the vehicle.
It's only a theory, but a possibility. Let me know if you have a scan tool that provides live data. If so, check two things. First, confirm the ECT (engine coolant temperature sensor) signal seems correct. If so, let me know what the short-term fuel trims are.
Jun 26, 2022 at 3:05 PM
JAMES SNIVELY
  • 7 POSTS
Thanks for your thoughts! I don't have a scan tool. I am going to replace the coolant temperature sensor within the next day or so when i get time. What you are saying makes sense. i have noticed the tailpipes are pretty black. I have not noticed smoke though. I will let you know how things turn out. Thanks much.
Jun 27, 2022 at 8:31 AM
  • 110,251 POSTS
James, please remember that there is a theory at this point. I don't like having people spend their money if it doesn't fix the issue. I hope you understand. However, it certainly could be the issue.
Regardless, let me know how things turn out for you. I'm interested in knowing.
Jun 27, 2022 at 1:29 PM
JAMES SNIVELY
  • 7 POSTS
Okay, i understand, no worries about if it doesn't fix it. I am running out of ideas as to what could be causing the problem and your theory makes sense enough to try. I have talked to my mechanic, and he agrees that it's possible. I am getting the sensor put it Wednesday morning. I'll let you know how it goes. Thank you
Jun 28, 2022 at 11:01 AM
  • 110,251 POSTS
Thanks for understanding. I look forward to hearing what is found. I'm interested in knowing.
Jun 28, 2022 at 12:19 PM
JAMES SNIVELY
  • 7 POSTS
Hello, well, i had the temperature sensor replaced and the problem still exists. i have noticed that it surges between 30 and 40 mph. transmission issue maybe? i had the car scanned but no codes came up from the computer.
Jun 29, 2022 at 10:55 AM
  • 110,251 POSTS
If it only happens at that speed, manually shift it past that speed to see if it still surges. If it doesn't, upshift to the next gear and see what happens. I don't feel it's the transmission, but anything is possible.
I know there was a technical service bulletin related to internal carbon build-up in the engine causing different drivability issues, but nothing at a specific speed.
Jun 29, 2022 at 4:15 PM
JAMES SNIVELY
  • 7 POSTS
The problem is intermittent which makes it harder to figure out. I'll let you know how things go, thanks again.
Jun 30, 2022 at 1:25 AM
  • 110,251 POSTS
James, you are very welcome, but I don't feel very helpful. If this issue was at any speed, there are several things to check, but since it is specific to a speed, that limits things.
As you said, since it's intermittent, it is more difficult. Actually, it can become frustrating.
Regardless, let me know and if there is anything I can do to help, let me know that as well.
Jun 30, 2022 at 12:39 PM
JAMES SNIVELY
  • 7 POSTS
hello Joe, i have taken the car to a person who specializes in foreign cars. He is going to check for a vacuum leak and any codes which come up from the computer which did not at O'Reilly's. I will let you know what is found out.
Jul 5, 2022 at 11:05 AM
  • 110,251 POSTS
Thank you for the update. I look forward to hearing what is found. I am interested in knowing.
Jul 5, 2022 at 3:12 PM
JAMES SNIVELY
  • 7 POSTS
Apparently a transmission issue. The trans fluid was replaced and it is much better. It was not flushed but replaced. It may need one more time. But it is so much better now..
Jul 8, 2022 at 9:56 AM
  • 110,251 POSTS
That's great news. Hopefully, one more time will make it perfect. Thank you for the update. If things change, let me know.
Jul 8, 2022 at 1:18 PM
