engine surging
2006 TOYOTA
105,000 MILES • 2.7L • 4 CYL • 2WD • MANUAL
GYPSY KATH
on starting it runs fine, but within a minute or two the engine starts surging and continues to do so regardless of revs.
I did have someone put a gauge on it to read the fault code so will see if they can do the fuel pressure. I did change the fuel filter, emptied and refilled the fuel tank as in rural areas the fuel can be dodgy at times.
Jan 18, 2017 at 7:08 AM
  • 55,743 POSTS
Hey GYPSY,
It sounds like it could be a coolant temperature sensor that is going out or you have a mass air flow sensor that can be give you trouble ,here are a couple of guides that can help you get the problem fixed.
https://www.2carpros.com/articles/engine-surges
and
and
https://www.2carpros.com/articles/mass-air-flow-service
Run some tests and get back to us so we can continue helping you.
Best, Ken
Jan 22, 2017 at 1:18 AM
