Engine surging
300,000 MILES • 2.7L • 4 CYL • 2WD • MANUAL
ROGERS MARK
Engine revs up and down at low speeds, no check engine light on.
Jun 3, 2021 at 6:34 PM
There are a number of things that can cause this so we need to start with this guide on this issue.
https://www.2carpros.com/articles/engine-surges
Below is a guide on testing for a vacuum leak which is the most likely cause of this.
Once we run through these guides we will have a better idea what the possible cause is. Let us know if you have questions or what you find and we can go from there. Thanks
Jun 4, 2021 at 12:55 AM
ROGERS MARK
Can't find vacuum leak. could it be the MAP sensor causing the surge problem? and where is the MAP sensor located on the hiace 2007 , engine 2TR - FE model TRH 201 /223? I can't locate it without workshop manual.
Jun 4, 2021 at 3:32 PM
Unfortunately, we don't have a manual on this specific engine as it is Mexico only and we don't have the detail.
If you have no external vacuum leak, I would hook a vacuum gauge to it and make sure the intake valves are not leaking either.
If you are not able to locate the MAP then it may not have one. This engine may use a mass air flow sensor and then it calculates the MAP based on throttle input and amount of air coming in.
Jun 5, 2021 at 12:06 PM
