Engine surges
115,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
STANLEY BLACKWELL
While driving engine surges at higher speeds.
Dec 8, 2018 at 2:23 PM
  • 55,711 POSTS
This sounds like the MAP sensor needs to be replaced. Tune up fresh? Here is a guide to help walk you through the steps and the location of the sensor for your truck below.
Lets run the codes to see if any come up. If the MAP is off a little it wont through a code..
This guide might help as well:
https://www.2carpros.com/articles/engine-hesitates
Cheers, Ken
Dec 10, 2018 at 8:51 AM
