How many engine support or mount it has? I've been searching on many internet sites and owner manual can't figure it out.
Nov 5, 2019 at 8:41 PM
BMDOUBLE
✓Experienced Mechanic
The main supports are on the front and the rear transmission mount, the mount on the front of the sub-frame is for torque and not weight, so 3 mounts. Here are pictures from the repair manual:
Images (Click to enlarge)
Nov 6, 2019 at 12:03 AM
MARLENE009
MEMBER
Thank you. I appreciate your help.
Should I replace all of the or just the broken one?
Nov 6, 2019 at 12:46 AM
MASTERWRENCH
Typically you only replace the ones that are broken. However, I would inspect the others for signs of wear or cracking. If you find any of this, it would be a good a idea to replace those as well.
