Engine suggested top end routine service?
52,000 MILES • 2.4L • AUTOMATIC
RJGLSL17
Car was taken to a dealer for routine service and the technician cleaned the throttle body, MAF, MAP and other sensors on the engine. I don’t know about the oxygen sensors. When I took the car in it was running well as it always had. When t got it back i didn’t notice any change in it until the next morning when the engine ran serging at engine speeds below 2000RPM. When the engine is warm the problem seems to disappear. I haven’t touched the engine but t bought some MAF and throttle body spray cleaner. I thought I’d ask if I was on the correct path and ask about the correct method for cleaning these parts.
May 7, 2026 at 12:26 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Retain the successful hose-reseating result and recheck operation from a cold start. If the symptom returns, have the disturbed intake connections and actual sensor layout inspected before repeating cleaning or replacing sensors. The thread's sensor identification was not independently verified. It is not necessary to repeat the owner's flammable-spray test to use the reported repair history.
Guidance references and applicability
Source discussion: question 1712711 https://2carpros.com/questions/engine-suggested-top-end-routine-service--1712711 Supports the reported history and outcome only. Follow-up guidance is editorial synthesis; unverified specifications and diagnoses are not adopted.
Read the replies · Discussion summary and reported outcome
  • 110,251 POSTS
Hi:
It sounds like they already did that, correct? Tell me. Is the check engine light staying on after the engine starts?
If the light does stay on or flash, we need to scan for diagnostic trouble codes. If you take the vehicle to a nationally recognized parts store, such as AutoZone, they will scan and provide a report to you free of charge.
Let me know about the light. Next, take a look under the hood. The MAF is mounted to the air inlet tube. Check to make sure it is connected. Also, make sure the air inlet (between the throttle body and air filter box) is properly attached and there are no vacuum leaks.
Try this and let me know the results.
May 7, 2026 at 7:38 PM
RJGLSL17
First of all, I did an inspection of the engine and found no evidence that the throttle body had been sprayed. The dirt on the air intake hose from the air filter had not been touched. Second, I couldn't find the MAF sensor. After some searching online, I learned that this engine doesn't have a MAF filter. Only the MAP sensor is used. That sensor had been handled and cleaned. As you suggested, I did a leak test by lightly spraying carb cleaner on the parts that I thought were cleaned. The MAP sensor hose clamp was tight but was a little crooked and the engine serged when that area was sprayed, I disconnected the hose and put in on straight. Car runs like a Swiss watch, no serging, hunting or rough idling.
Thanks for the help. I'll be back if I have any other problems with this car.
May 8, 2026 at 8:27 AM
  • 55,859 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
May 10, 2026 at 9:56 AM
Discussion summary
The owner reported cold-engine surging after a service visit involving sensor cleaning. Inspection found a crooked hose connection that the owner associated with the MAP sensor. After disconnecting and reseating that hose straight, the owner reported smooth running without surging, hunting or rough idle.
Reported outcome: The owner reported that reseating the hose restored smooth operation.
The exact hose and sensor arrangement were not documented with a diagram or image. The report establishes the owner's observed result, not a verified component-location guide.
Read the original discussion
