Engine stutters and seems to bog down
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
DRHEAT12
I have an issue that occurs when driving. In od the engine seems to want to die out. It stalls and stumbles along jerk in the truck violently. This also happens in park when you snap the throttle. New cap, rotor wires and plugs. I switched to high octane fuel and used injector cleaner. The problem happens when the engine is at operating temp. I consider myself pretty good with cars and trucks but this has me stumped. Any advise or direction would be greatly appreciated.
May 2, 2016 at 9:34 AM
HMAC300
  • 48,601 POSTS
have a trans guy scan for codes it may be a torque converter problem.
May 2, 2016 at 11:41 PM
DRHEAT12
  • 0 POST
There were no codes or apparent torque converter issue. They said it's not the trans because it happens in park.
May 9, 2016 at 4:04 AM
  • 55,781 POSTS
It sounds like the ignition coil could be going out, have you done an voltage output test?
Here is a guide
Let me know
May 10, 2016 at 5:05 AM
