When I drive my truck for about 20 minutes, and it gets up to temperature the motor will sputter once or twice at a red light then will stop
205,000 MILES • 5.9L • 6 CYL • TURBO • 4WD • AUTOMATIC
RAGUEVAN
The RPMs will drop almost to stalling then return back to normal idle while in drive. It does it in all gears. I haven’t been able to find any symptoms of anything either
Jun 20, 2022 at 2:38 PM
  • 55,785 POSTS
This can happen when the throttle actuator gets dirty and needs to be serviced. Here is a generic guide to help you see wat you are in for and specific instructions in the diagrams below to show you on our car:
it can also be a vacuum leak which is common please, do this check when the engine is cold.
Jun 22, 2022 at 12:48 AM
RAGUEVAN
Hey Ken, thanks for the great information. I forgot to mention that it is a diesel truck. I don’t know if that changes any of the diagnosis. I totally forgot to mention that in the first question.
Jun 22, 2022 at 1:43 AM
  • 55,785 POSTS
You can still use the guides, but it sounds smore like the engine coolant sensor is shorting out. but we should run the codes first, here is a guide to follow, let me know what you come up with:
Jun 23, 2022 at 2:22 AM
RAGUEVAN
No codes show up when the problems happen. That’s why I was a little stumped with this issue.
Jun 23, 2022 at 12:34 PM
  • 55,785 POSTS
I would start by servicing the fuel filters; you could have water in the fuel. here is a video to help and instructions for your truck in the diagrams below:
https://youtu.be/6de-1mIpzi8
Jun 24, 2022 at 2:30 AM
