i had the exhaust removed and now it stops after 20+ miles.? why
Apr 21, 2013 at 7:23 AM
✓Experienced Mechanic
ok, why did you remove the exhaust??? If the service engine light is on, have the codes read and post them here for further assistance.
Apr 21, 2013 at 8:01 AM
HMAC300
what specifically was removed? if any of the O2 sensors were removed the computer isn't reading it so that may be the problem. check your fuel pressure as well. Other than that can't think of much why it would. Is the computer still hooked up has this been modified in any other way?
