Engine stops running sometimes
197,772 MILES • 4.9L • V8 • 2WD • AUTOMATIC
REARDRIVE
  • 93 POSTS
The car start up , runs awhile then it just stops running. The day it will crank up and stay running.
Aug 9, 2020 at 12:38 AM
Good morning,
When it shuts off, does it start right back up or do you have to wait for a while?
https://www.2carpros.com/articles/engine-stalls
I would check the fuel pressure to be sure the pump is good. It will need to be tested when it stalls.
Spark also needs to be tested as well.
Is the check engine light on? If it is, can yo tell me the code?
Aug 9, 2020 at 1:11 AM
