Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Cadillac
Deville
Engine
Symptoms
Stall While Driving
Engine stops running sometimes
1992 CADILLAC DEVILLE
197,772 MILES • 4.9L • V8 • 2WD • AUTOMATIC
REARDRIVE
MEMBER
The car start up , runs awhile then it just stops running. The day it will crank up and stay running.
Aug 9, 2020 at 12:38 AM
Experienced Mechanic
Good morning,
When it shuts off, does it start right back up or do you have to wait for a while?
https://www.2carpros.com/articles/engine-stalls
I would check the fuel pressure to be sure the pump is good. It will need to be tested when it stalls.
Spark also needs to be tested as well.
Is the check engine light on? If it is, can yo tell me the code?
Aug 9, 2020 at 1:11 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
