Engine start issues and misfire
138,000 MILES • 4.3L • V8 • 2WD • AUTOMATIC
CHEFJACKL12
Car cannot seem to turn over without a jumper boost even with a new battery and cables. When driving I can hear it misfire and some backfire sputtering.
Sep 10, 2017 at 12:19 AM
JDL
  • 16,098 POSTS
How long since a tune-up? As far as your starting system. I would use a digital multi-meter across battery posts, everything off, the generic spec for a full charge is around 12.6 volts. Leave the leads touching battery posts, have helper turn key to crank, how far does the reading drop, should not drop below 9 volts, just my opinion. I saw what you replaced, did you check your charging system?
You may have to check voltage drop on wiring circuits going to starter motor. Hopefully your engine is not hard to crank for some reason?
Sep 10, 2017 at 5:16 AM
