Engine starts but cuts off
200,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
HSHENNIEB474
The engine start but cuts out as soon as you accelerate. I have cleaned the air flow sensor, but problem still exist.
Aug 31, 2018 at 4:46 PM
  • 110,248 POSTS
Have you checked to make sure the fuel pressure is within the manufacturer's specifications? Here is a link that shows in general how to check fuel pressure:
That is where I would start. Keep in mind, when the engine is placed under a load, more fuel is required. That could be the issue.
Sep 2, 2018 at 12:27 PM
HSHENNIEB474
Hi there,
We have checked and found that there is no fuel pressure. We have changed the fuel pump which sorted the problem out.
Thank you so much.
Sep 3, 2018 at 6:40 AM
  • 110,248 POSTS
Great! I am glad you got it fixed. Let me know if you have questions in the future.
Sep 3, 2018 at 12:37 PM
