Engine stalls when the transmission is shifting to park?
35,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
LEWISC13B
  • 21 POSTS
I have been having this issue where my car will stall or almost stall when placed in park. When I start the car there are no noticeable issues, and when I drive the car, or stop at lights there are also no noticeable issues. This only happens occasionally once I reach my destination and place the car in park the RPMs will drop significantly and go back up above 1000 to keep the car alive or stall completely. I have modified the car some with long tube headers and high flow catalytic converters, as well as a tune. There are two codes, P0420 and P0430, which I have been told is normal due to the O2 sensors having different readings of the high flow catalytic converters which is different than the stock readings, causing the codes. My tuner says my fuel numbers look great, and mechanics either can't replicate the issue or can't find what's causing it. Please help!!
Aug 29, 2023 at 10:51 PM
  • 55,694 POSTS
Thanks for the video, it helps. Does the car have 35,000 miles? If so, I would say there is something wrong with the tune. If it has more milage I would service the throttle bore and check for vacuum leaks, here are guides to help us see what's going on:
https://www.2carpros.com/articles/stall-at-idle
And use this guide when the engine is cold only:
Here is how to service the throttle bore:
Aug 30, 2023 at 5:16 AM
LEWISC13B
  • 21 POSTS
Yes, it does have 35,500 miles. I've been chasing this issue for some time, with two separate tuners. My new tuner had reviewed my logs and explained my fuel trims looked perfect. He sent me a new tune which I believe increased the idle RPMs, but the issue is still there. I just find it weird it only ever happens when shifting to park.
Aug 30, 2023 at 5:56 AM
LEWISC13B
  • 21 POSTS
I forgot to mention it also has a cold air intake that I installed myself, if you think that might cause the issue maybe?
Aug 30, 2023 at 5:58 AM
  • 55,694 POSTS
I don't think the cold air intake will cause this problem. Does the engine have a cooling system thermostat? Also does the new intake have a place for the IAT sensor port?
Aug 31, 2023 at 3:31 AM
LEWISC13B
  • 21 POSTS
Yes, it has a thermostat and the IAT is integrated into the MAF from my understanding, which is installed in the new intake. Another possible culprit I'm researching is the obvious, the P0420 and P0430 codes for the O2 sensors reading below threshold. I do have headers and high flow catalytic converters, but maybe the car is adjusting AFR because of it? I'm considering using spacers to give distance to the downstream O2 sensors to see if that helps. The only reason I want to try is every time I attempt to datalog the issue it doesn't happen. But when it starts again usually the CEL follows the next day, which I just use my handheld to clear the DTCs.
Aug 31, 2023 at 4:59 AM
  • 55,694 POSTS
Yep, good call on the oxygen sensor spacers which should help. I have seen the trick before and it works good. Please let me know what happens.
Sep 1, 2023 at 1:59 AM
LEWISC13B
  • 21 POSTS
Me again!
Over the weekend I tried the spacer trick, CEL and codes are now gone and for a couple of days I believed my issue was resolved. However yesterday I found out that the issue is still present. I'm currently waiting for my tuner to review the log to give me some feedback. I'm baffled by this, because it only happens every so often after the engine has been driven and is warm. When it does happen its bad, I can usually tell when it's about to happen because after I put the car in park it's like everything goes silent before the RPM surge, and I have done a lot of exhaust work so it's noticeable.
Sep 6, 2023 at 12:45 AM
  • 55,694 POSTS
It does sound like the tune is causing the problem, let me know what the log says?
Sep 8, 2023 at 8:24 AM
LEWISC13B
  • 21 POSTS
Tuner said he noticed some oscillation in spark. So, he sent a new tune to help with the issue. It worked for about a day and was right back. Called him and he mentioned that the spark plugs could be the culprit, and driving a V8 engine in Arizona weather probably doesn't help. So today I replaced all 8 spark plugs, so far so good I'm sure the ECU might be relearning after everything so I'm going to give it a couple of days and report back.
Sep 8, 2023 at 11:23 AM
  • 55,694 POSTS
Good call, the spark plugs can cause the problem and I have seen counterfeit spark plugs on Amazon as well so be on the lookout for that. Have a good weekend.
Sep 9, 2023 at 2:59 AM
LEWISC13B
  • 21 POSTS
Thank you! Just an update, it was not the spark plugs, battery, or alternator. Had the plugs replaced with brand new OEM ones and the battery and alternator checked everything was good. I broke and decided to just take it to a shop so they could run diagnostics. I'm tired of chasing the issue, lol.
Sep 9, 2023 at 4:18 AM
  • 55,694 POSTS
Sorry we could guide you to the solution, please let us know what the problem was.
Sep 11, 2023 at 3:43 AM
LEWISC13B
  • 21 POSTS
Good morning. I still haven't found the issue lol. Some new information, when I put the car in park the RPMs do search a bit, but today when I turned the A/C on after putting it in park it almost completely stalled out. Any ideas?
Sep 19, 2023 at 2:09 AM
  • 55,694 POSTS
Just the guides above, I still think it is the tune if the guides above yield no results, what did the shop say?
Sep 20, 2023 at 10:54 AM
LEWISC13B
  • 21 POSTS
Both shops said they couldn't identify the issue and just offered to change the oil. I will be double checking the throttle body this weekend. I switched to a third Tuning company recently and the issue is still present. My first suspect is the throttle body, second is the voltage regulator, part of me believes it's an electrical issue, mainly the TB thinking adding extra load like the fan and maybe the TB is malfunctioning, or the voltage regulator is producing weird patterns. The search will continue, lol.
Sep 20, 2023 at 11:40 AM
  • 110,248 POSTS
I noticed we haven't contacted you for a couple of days. Have you been able to make any progress? We are interested in knowing.
Sep 22, 2023 at 4:28 PM
LEWISC13B
  • 21 POSTS
I think so. I decided to just clean my MAF and throttle body this weekend as well as check all hoses. I have the JLT II cold air intake. I guess the grommets were not the best quality and after lightly removing the connector this grommet split in half. It was in very rough shape. This is to one of the PCV hoses, so I believe it was a small vacuum leak.
Sep 23, 2023 at 9:51 AM
  • 110,248 POSTS
Certainly, that can cause an issue. Does it seem like the problem has been resolved since they were replaced?
Sep 23, 2023 at 12:00 PM
LEWISC13B
  • 21 POSTS
I'm not sure yet I'm looking for replacements currently that will seal properly. I'll report back in a few days.
Sep 23, 2023 at 12:46 PM
LEWISC13B
  • 21 POSTS
Hello, I am finally back with an answer to my issue. I've replaced a bunch of stuff and finally given up lol. After extensive research and thinking, I believe my issue is the cold air intake. The intake I have is open with a heat shield that blocks heat from the engine but not the front of the car. I also live in Arizona where temperatures are above 100 most days. What I believe my issue is, is the heat wash from my fan blowing at the intake filter causing an increase in the IAT as well as turbulence inside the intake and around the MAF. It makes sense in my head because after going into park, the car does not have outside air blowing to cool the engine and instead now relies on ambient temperatures, under the hood temperatures, and the fan blowing the hot air at the intake while in closed loop causing the car to adjust the fuel to be leaner to compensate and thus causing the surge. I'm no expert so please let me know if this doesn't make sense.
Sep 26, 2023 at 12:36 PM
  • 110,248 POSTS
Absolutely, that makes sense. Have you been able to resolve the issue?
Sep 26, 2023 at 1:07 PM
LEWISC13B
  • 21 POSTS
Yes.
Sep 26, 2023 at 10:22 PM
  • 110,248 POSTS
Excellent! That is good news and thanks for letting me know.
Take care of yourself and feel free to come back anytime in the future.
Sep 27, 2023 at 11:57 AM
