Engine stalls when braking
170,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
VAUGHN GRUENEWALD
When I apply the brakes my car stalls at a stop or when slowing down to a stop. And when braking my turn signals illuminate on the dash. Anyone know what it might be.
Feb 9, 2020 at 7:03 AM
  • 110,248 POSTS
You have a couple things happening. The signal lights turning on indicates a bad ground at the rear lights. What is happening is there is a poor ground for the brake lights. So, power is back feeding anywhere it can to make a ground. In this case, through the signal light circuit.
As far as the stall. If you are sitting with the vehicle running and in neutral, does it stall if you press the brakes? If it does, then either we are dealing with an engine vacuum issue or it could be related to a ground issue.
I will help with the signal lights once I determine what is happening with the stalling. However, I feel they may be related via a bad ground.
Feb 9, 2020 at 1:23 PM
VAUGHN GRUENEWALD
It does stall in neutral if parked when brakes are applied.
Feb 9, 2020 at 10:15 PM
VAUGHN GRUENEWALD
And what side would the ground be on for rear lights?
Feb 9, 2020 at 10:17 PM
  • 110,248 POSTS
You need to check for an engine vacuum leak. I suspect it is at the power brake booster. Follow this link and let me know what you find.
I'm not sure what you mean by what side the ground is on. Can you explain?
Feb 10, 2020 at 8:26 AM
