Engine stalls upon slowing down or at stop
140,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
JAMES SMITH2
Engine seemed to run a bit hot, never had a light but i did have fluid drainage and the hoses were extremely hot to touch after a short drive. i replaced the thermostat and lower radiator hose and cap, went to drive the car it ran fine until i had to slow down for a red light or traffic then it would die, but would start right back up, I thought the carb was goen bad, fluding out or needed adjusting, but the next day i replaced the radiator cap again this time with a heavy duty one(higher psi) went to drive the car an she ran great never stalled out no drainage noticed, has anyone ever had this issue, or heard of this problem?
Aug 27, 2016 at 1:51 PM
CJ MEDEVAC
  • 11,000 POSTS
Sounds like carb mix screws need adjusting or maybe the idle speed is too low.
The Medic
Aug 27, 2016 at 2:03 PM
JAMES SMITH2
Ok thanks i will look into that, i will br taking it on a test drive today in warmer weather to see how the car acts, the was sitting for almost a month getting re wired, so i was hoping it just needed to be drove some, thanks again for the info
Aug 28, 2016 at 1:35 AM
CJ MEDEVAC
  • 11,000 POSTS
This may aid you if you can "translate" it to your vehicle. See this link
https://www.2carpros.com/questions/jeep-cj7-1985-jeep-cj7-stalls-when-hot
If you can't seem to
Get rid of yours and get a Jeep CJ, No translating will be necessary then!!! LOL!
Good luck, keep us posted on progress
The Medic
Aug 28, 2016 at 2:03 AM
JAMES SMITH2
Hey thanks great info!, i just replaced the throttle arm spring, the old one was crap and the car kept having high rmps, i am goen on a test run for about 30 min or so i will up date later on today with any further issues, an jeeps are nice but im a die hard CHEVY MAN lol
Aug 28, 2016 at 3:05 AM
JAMES SMITH2
1963 SS IMPALA
Aug 28, 2016 at 3:07 AM
CJ MEDEVAC
  • 11,000 POSTS
Let me know if the info makes it run better.
That looks really sharp and cared for.
I'd say you might could swap it for a Jeep, I doubt the Jeep guy would turn his loose! LOL!
The Medic
Aug 28, 2016 at 8:24 AM
