Engine stalls at idle after few minutes
224,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
WGARRIGUS
Engine stalls at idle after few minutes then will restart within three minutes. restarts easily and runs smooth at restart and first start.
Mar 2, 2019 at 4:43 AM
Good afternoon,
When it does not start, did you check for spark and can you hear the fuel pump run?
It could be either. Spark is a more common issue.
Mar 2, 2019 at 5:53 AM
WGARRIGUS
Thanks for quick replay. It was fuel pump main relay.
Mar 3, 2019 at 12:10 PM
Very common failure.
Glad you got it fixed.
Mar 3, 2019 at 1:07 PM
