Engine stalls at cold start
315,000 MILES • 4 CYL • 2WD • MANUAL
BELMONT$
My engine stalls about 50% of the time at cold start. I depress the throttle to the floorboard as usual and it starts right up and goes up to about 2700 RPM. Within 30 seconds the engine dies unless I keep pumping the throttle. Once warm, it runs perfectly. Please help me on this.
Nov 25, 2018 at 6:06 AM
  • 110,248 POSTS
Your vehicle has a carburetor with a vacuum and thermo choke assembly. Now, based on what you are telling me, it sounds like the choke is not staying closed enough when the engine is cold. That can be the result of a vacuum issue, an engine vacuum issue, or the linkage on it is blocked or needs adjusted.
Here are the directions for checking and adjusting. You will need a general vacuum pump which most parts stores will lend or rent to you. Follow the directions to make sure things are working correctly, there are no vacuum leaks, the choke is closing and opening correctly based on temperature, and the linkage isn't being blocked by something.
_________________________________
STANDARD PROCEDURE
Fig. 9 Choke linkage adjustment, first stage. See picture 1
1. Remove air cleaner and choke coil
2. Disconnect upper choke opener hose from thermo valve and leave open to atmosphere, and disconnect lower hose and connect suitable vacuum pump to thermo valve.
3. Apply at least 8 inches Hg vacuum to thermovalve. If vacuum drops below 8 inches Hg, vacuum pressure has opened bleed valve. Slowly reapply vacuum until highest vacuum reading can be maintained; this will bring opener rod as close as possible to bleed valve without opening valve.
4. Rotate choke drive lever counterclockwise until it contacts choke opener lever, then measure choke valve clearance, Fig. 9.
5. If 1st stage clearance is not .119-.125 inch for manual transmission models or .091-.097 inch for automatic transmission models, adjust by bending tab A, Fig. 9.
Fig. 10 Choke linkage adjustment, second stage. See picture 2
6. Plug upper port on thermo valve, pull choke opener rod to the fully extended position by applying 6-7 inches Hg vacuum to lower port, Fig. 10, rotate choke drive lever counterclockwise until it seats against choke opener lever, then measure choke valve clearance.
7. If 2nd stage clearance is not .200-.208 inch, adjust by bending tab B, Fig. 10.
Fig. 11 Choke linkage adjustment, third stage. See picture 3
8. Continue holding opener lever against tab, rotate choke drive lever until tab C contacts spring, then measure choke clearance, Fig. 11.
9. If 3rd stage clearance is not .394-.412 inch, adjust by bending tab C, Fig. 11.
10. Reinstall choke cover and adjust as outlined.
____________________________________
Let me know if this helps. Also, if you have questions or need help, let me know.
Nov 25, 2018 at 12:07 PM
BELMONT$
Joe:
Thank you so much for your expertise and your well written details! The Honda dealership was not interested in diagnosing and two other mechanics had a look at could not help. I wish you could work on this for me. Yes - I own a hand held vacuum gauge. By the way, I sprayed the linkage with carburetor cleaner with no luck.
Please refer to your first item 1 above. I believe you mean remove air cleaner and choke cover, not coil. Please advise me.
Can I assume removing the air cleaner is only to obtain access? It looks like there's a multitude of other hoses are in the way in order to access the coil spring housing. Ugh!
For the measurements shown on the sketches, I do not understand what the upper horizontal line is measuring to.
And - what measuring device to you guys use to get an accurate readings as measured on the horizontal in such a limited space and, worse, being unable to measure directly parallel to the choke drive. i.e., it is not directly in the line of sight? Feeler gauges?
Steve
Nov 27, 2018 at 2:13 AM
  • 110,248 POSTS
The horizontal measurements are showing where to measure opening between choke valve and housing. Each step is for a different adjustment which shows the choke valve opening further.
You are correct about step 1. The cover/coil issue. Basically, they are the same thing. It will be a black cover over the thermo unit.
Now, and do not laugh, I still have a choke adjustment kit from the early 1980's. The gauges in the kit are similar to a feeler gauge, but are round. A feeler gauge will work just fine. My only concern is that the choke valve is not flat. Thus a flat gauge may make it tough.
What I think is happening with your vehicle is (and this is an educated guess) there is a vacuum leak or issue to the upper port of the thermo valve. If there is, the lower port vacuum will open the choke easily and not allow the engine to warm up via the choke.
Think about it. The choke properly sets when you depress the throttle before starting and the car starts easily. Once you release the high idle, there is no longer vacuum to the upper thermal valve and the vacuum to the lower pulls open the choke. Not being there makes this a theory. Before you make any adjustments, I would check those things first.
Let me know how it goes for you.
Nov 27, 2018 at 10:45 AM
