Good morning.
Why did you replace the crank sensor?
Did you have this issue prior to the repair?
The 300 codes are misfire codes and could be caused by the crank sensor.
The 1753 is a transmission code.
P0135
Descriptor
Probable Causes
Engine Control Module (ECM)/Powertrain Control Module (PCM)
Fuse
Heated Oxygen Sensor (HO2S) 1
No. 6 ECU (ECM/PCM) CRUISE CONTROL (15 A) Fuse In Driver's Under-Dash Fuse/Relay Box
Poor Connections or Loose Terminals Between Heated Oxygen Sensor (HO2S) 1, HO2S 2 and Engine Control Module (ECM)/Powertrain Control Module (PCM)
Wire Between Engine Control Module (ECM)/Powertrain Control Module (PCM) C1 and Heated Oxygen Sensor (HO2S) 1 Heater Circuit Open
Wire Between Engine Control Module (ECM)/Powertrain Control Module (PCM) C1 and Heated Oxygen Sensor (HO2S) 1 Heater Circuit Shorted
Wire Between No. 6 ECU (ECM/PCM) CRUISE CONTROL (15 A) Fuse and Heated Oxygen Sensor (HO2S) Open
1753
P1753
Descriptor
Probable Causes
Loose Terminal On Powertrain Control Module (PCM) Connectors
No. 6 (15 A) Fuse In Driver's Under-Dash Fuse/Relay Box
Torque Converter Clutch Solenoid Valve/Shift Solenoid Valve A
Wire Between D1 Terminal and Torque Converter Clutch Solenoid Valve Open
Wire Between D1 Terminal and Torque Converter Clutch Solenoid Valve Shorted to Ground
Wire Between D1 Terminal and Torque Converter Clutch Solenoid Valve Shorted to Power
Wire Between D5 Terminal and Driver's Under-Dash Fuse/Relay Box Open
Wires Between B20 and B22 Terminals and Ground (G101) Open
Nov 15, 2018 at 8:37 PM
