The Engine stalls after startup, the vehicle has been scanned but there are no codes. If ignition coil No 1 is removed, the effects on the engine performance won't be much. I have swapped the ignition coil but there is no improvement.
Could I the engine performance wire diagram to trace some of the wires?
Oct 6, 2023 at 11:16 AM
