Engine stalls after four minutes at idle
70,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
STEVE SCHWUCHOW
  • 6 POSTS
Drove to work, okay.
Left work stalled leaving the lot. Unable to restart and was towed home.
Started but stalled out after four minutes. Unable to restart until two hours later.
OBD2 showed misfire in all four cylinders.
Replaced all spark plugs and coil packs.
No change in symptoms.
Called mobile mechanic .
He scanned it. Same codes. He thought it was starving for fuel.
Checked fuel pump working fine.
Fuel filter fine.
He thinks it may be a sensor somewhere, but he is not sure since no code is given by the OBD2.
He has now given up.
Any suggestions would be appreciated.
Thanks
Mar 14, 2017 at 1:32 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked the compression yet?
Mar 15, 2017 at 12:49 PM
STEVE SCHWUCHOW
  • 6 POSTS
Not yet. Still in my garage. However it will start and stay running with the MAP sensor unplugged. When I plug it in, it stalls. Thanks
Mar 22, 2017 at 9:48 PM
SATURNTECH9
  • 30,869 POSTS
I need the exact code numbers not code descriptions you have?Also your complete vin number.I asked around the shop and we just had one same year make model and it needed a ecm calibration update.
Mar 23, 2017 at 5:56 AM
STEVE SCHWUCHOW
  • 6 POSTS
Codes PO301, 302, 303, 304 when MAP plugged in
Codes P0108, P0113 when MAP unplugged
VIN to follow....
Car will start and run rough with MAP unplugged.
Will stall when MAP is connected
Mar 23, 2017 at 7:32 AM
STEVE SCHWUCHOW
  • 6 POSTS
VIN 3VWD17AJXEM360053
THANK YOU!
Mar 23, 2017 at 8:08 AM
  • 55,688 POSTS
Hey Steve,
It sounds like the MAF is shorted out, here is a guide that will show you what you are in for when replacing it.
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Please let me know if you need anything else to get the problem fixed.
Best, Ken
Mar 27, 2017 at 9:09 AM
STEVE SCHWUCHOW
  • 6 POSTS
Thanks Ken. I thought that may be the case as well, but the 1.8 Turbo TSI doesn't even have a MAF sensor. I know, crazy right?
Mar 27, 2017 at 11:24 PM
  • 55,688 POSTS
Sorry MAP sensor. I would also check the catalytic converter as well it could be partially plugged. Here is a guide.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Best, Ken
Mar 28, 2017 at 11:22 AM
SATURNTECH9
  • 30,869 POSTS
I can't find a tsb for that car like the one we had.Have you checked for air leaks on your inner cooler tubes etc?
Mar 28, 2017 at 12:07 PM
STEVE SCHWUCHOW
  • 6 POSTS
Ok.... it was.....a fried ECM. Luckily it has an 8 yr/80k mile warranty. It's a 2014 with 70k miles. Lucky me. Thanks everybody.
Apr 27, 2017 at 9:06 AM
  • 55,688 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
Apr 29, 2017 at 3:11 AM
