Engine stalls after 2 blocks or maybe 25 miles
DICK2256
  • 1992 BUICK PARK AVENUE
  • 3.8L
  • V6
  • FWD
  • 184,647 MILES
After it stalls It won't start right back up but after a 3-4 minute wait it will start up have checked the fuel pressure and it is 38-45 PSI the code lights I receive are 14, 41, 44.
just started this a few day ago doesn't appear to be getting any worse it just isn't safe to drive in weather like we have been having
Thursday, January 16th, 2014 AT 11:46 AM
WRENCHTECH
  • 20,761 POSTS
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Thursday, January 16th, 2014 AT 12:43 PM
Related Engine Stall While Driving Content
