Welcome to 2CarPros.
Since the vehicle has a carburetor, there are a couple concerns. First, make sure there are no engine vacuum leaks. Here is a link that shows how that is done:
Next, I need you to make sure the choke butterfly is staying open when the engine is warm. When you press it to the floor, the linkage forces it open, but that won't happen under normal acceleration.
In addition to a carburetor issue, check the vacuum advance to make sure it is working properly. This vehicle has a vacuum operated advance system. Make sure it is advancing under a light load. You can do this with a timing light.
Two other thoughts, does it still have points and condenser? If it does, check the condition of the points to make sure they are in good condition. Then, confirm dwell is correct. It really makes a difference if you set the points by eye or a feeler gauge compared to setting dwell correctly. Dwell on a 6 cylinder should be between 30 and 35 degrees.
Last, with the engine off, confirm the accelerator pump is shooting a small amount of gas into the carburetor's venture when you move the throttle slightly. It may be working at wide open throttle but not at a lower load situation.
Do these things and let me know if you have questions and what you find.
Mar 16, 2019 at 1:55 PM
