Car starts up but when driven a few ways it stalls.
Feb 19, 2021 at 1:30 PM
✓Experienced Mechanic
When it stalls can you turn the key off, then on can you hear the fuel pump run in the tank? if so I have seen this problem before and you need to clean your throttle body. here is a guide to help you with the repair:
