Engine stalls
196,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
PEDAL2DMETAL
Car starts up but when driven a few ways it stalls.
Feb 19, 2021 at 1:30 PM
  • 55,710 POSTS
When it stalls can you turn the key off, then on can you hear the fuel pump run in the tank? if so I have seen this problem before and you need to clean your throttle body. here is a guide to help you with the repair:
This guide can help as well:
https://www.2carpros.com/articles/stall-at-idle
Feb 21, 2021 at 1:35 AM
