Engine Stalling when reaches Opearting temp range
275,000 MILES
PEARLHICKORY
  • 69 POSTS
Hi guys, Ive got a 05 Ford f250, 6.0,,,[ truck was inherited ] I had starter problem a while back swapped it , ran good couple months then all of sudden started shutting down after it reaches midway on temp gauge like something is heating up and shutting down,, it will start back up again after few hours when its totally cooled down ,, any ideas please help,,
May 1, 2013 at 12:48 AM
fuel delivery system is real complicated and there are many items that have to be checked with a scan tool and gauges. you need a shop to check these for you
common issues are crank sensor, IPC solenoid and sensor. and lastly, high pressure oil pump.
May 1, 2013 at 10:52 AM
