Had a bank 1 o2 sensor code, converter code, coolant code, and evap code; replaced sensor, cleared coolant because it had run low at one point and has been filled, replaced gas cap, and cleared all codes, ran through drive cycle and no codes.
Replaced ignition relay, replaced ignition switch, put in a new battery… still stalling in park… even faster to stall when the A/C is running. Does not stall in other gears. Help!
Aug 6, 2023 at 7:33 AM
