Engine stalling, dashboard instruments not working
200,000 MILES
ULRICH07
My car stalls when idling. If I try to restart it, the key makes a clicking noise, but the engine does not react. If I come back later, it can start again.
The dashboard instruments do not work, but before they stopped working the battery warning light was briefly on.
I assume that the battery is busted, but I was wondering if it could be the alternator instead. Is there any way to tell based on the symptoms?
Jul 18, 2021 at 5:09 AM
SQM
  • 6,383 POSTS
We will probably need more info in order to diagnose the issue.
For a no start scenario it could be simple as battery, but also can be fuel or ignition related.
I have seen faulty coolant temperature sensor preventing a engine from starting or stalling.
Also crank sensor could be another possibility.
Do you know if your check engine light is on?
If so what are the codes?
https://youtu.be/vMwTzURWXmk
Please let me know little more info.
Thank you,
Jul 18, 2021 at 8:53 AM
