oil pressure fluctuates, then goes to zero, engine stalls?
120,000 MILES • 4.7L • V8 • RWD • AUTOMATIC
ADEDEJI ADELAJA
My truck is rough running, the check gauges light, oil pressure fluctuates, then goes to zero, engine stalls.
Jul 15, 2016 at 2:59 PM
  • 55,676 POSTS
It sounds like the engine is out of oil, I would check the oil and if low let's change it out for fresh oil and filter. Also, we should run the codes to see what comes up then we can go from there to help fix the problem.
This video will help show you how:
https://youtu.be/_htZR6yCrXE
And this generic guide will help walk you through the steps:
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Use this guide to help gather the codes:
Jul 24, 2022 at 5:38 AM
