Engine stalling
23,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
WASU
Checked injectors and noticed injector one is not injecting fuel. Placed injector two wiring on one and it was injecting. Noticed no spark on plugs one and four. Changed crank sensor and coil, car behaves the same. The car came to a halt while driving. Thats when I noticed the rough idling and had to conduct those tests on the injectors, and spark plugs. Please help.
Aug 18, 2018 at 12:42 AM
  • 55,627 POSTS
It sounds like the PCM has gone bad. I would try to find a used one and swap it out to see if the problems goes away. But first lets try check the injector and coil pulse to confirm the issue. Here are two guides, please run down them and get back to me:
and
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Cheers, Ken
Aug 23, 2018 at 2:48 AM
