Engine cranks but no start
105,000 MILES • 1.8L • 4 CYL • FWD • MANUAL
11 NARWHAL
Experience start problems when cars cold,after a small drive,car starts without fail.if it is crank sensor or fuel pump, would the car not drive properly, because it drives smoothly. what else could problem be?
Sep 12, 2016 at 3:35 AM
  • 55,746 POSTS
So does it not start when it is hot?
Sep 16, 2016 at 1:27 PM
MAXIMILIAM
  • 436 POSTS
Starting problems.yes my car will start every time without fail.
Best Regards,
11 Narwhal
Sep 20, 2016 at 1:46 AM
  • 55,746 POSTS
It sounds like the coolant temperature sensor is bad, can you scan for codes? Here is a guide that will help you.
Please let us know what you find so it will help others.
Best, Ken
Sep 20, 2016 at 3:53 AM
