Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cobalt
Engine
Symptoms
Stall While Driving
Engine stalling
2006 CHEVROLET COBALT
160,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
SAMGREW
MEMBER
When running engine will stall, gauges go crazy (erratic jumping) and radio makes lots of noise.
Aug 1, 2019 at 4:26 AM
Experienced Mechanic
Good afternoon,
Does the engine start right back up?
https://www.2carpros.com/articles/engine-stalls
Aug 1, 2019 at 6:07 AM
SAMGREW
MEMBER
Unknown, was told later problem started after starter was replaced.
Aug 2, 2019 at 12:37 AM
I need to know this information. How do you know if it is good if you do not know the voltage?
Aug 2, 2019 at 1:36 AM
SAMGREW
MEMBER
Looked at car myself. Also not stalling. Code is P700.
Aug 13, 2019 at 5:27 AM
OK, check the battery cables connections and make sure they are clean and tight.
Why did you replace the starter?
Aug 13, 2019 at 5:33 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
