HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Cobalt
Engine
Symptoms
Stall While Driving
SPONSORED LINKS
Engine stalling
SAMGREW
MEMBER
2006 CHEVROLET COBALT
2.2L
4 CYL
2WD
AUTOMATIC
160,000 MILES
When running engine will stall, gauges go crazy (erratic jumping) and radio makes lots of noise.
Thursday, August 1st, 2019 AT 11:26 AM
MECHANIC
Good afternoon,
Does the engine start right back up?
https://www.2carpros.com/articles/engine-stalls
SPONSORED LINKS
Thursday, August 1st, 2019 AT 1:07 PM
SAMGREW
MEMBER
Unknown, was told later problem started after starter was replaced.
Friday, August 2nd, 2019 AT 7:37 AM
MECHANIC
I need to know this information. How do you know if it is good if you do not know the voltage?
Friday, August 2nd, 2019 AT 8:36 AM
SAMGREW
MEMBER
Looked at car myself. Also not stalling. Code is P700.
Tuesday, August 13th, 2019 AT 12:27 PM
MECHANIC
OK, check the battery cables connections and make sure they are clean and tight.
Why did you replace the starter?
SPONSORED LINKS
Tuesday, August 13th, 2019 AT 12:33 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
Runs For Five Seconds Then Dies
I Have Four Codes, Po496, Po141, Po455, Po446. I Was Driving The Car And It Died As If It Ran Out Of Gas, It Had A Full Tank Of Gas. I...
Asked by
Roger Meadows II
1 IMAGE
2006
CHEVROLET COBALT
VIDEO
Code Read Retrieval/Clear Chevrolet
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
Starts And Runs Then It Shuts Off After Engine Has...
A Friend Jumped My Daughters Car, It Started And Ran, Then She Noticed The Fuel Gauge Was Not Working Correctly And The Speedometer Was...
Asked by
Nick Raschella
1 IMAGE
2005
CHEVROLET COBALT
Why Is My Car Having Troule Starting And Shutting Off?
When I Go Get Gas And The Problem Only Occurs When I Go Get Gas, The Car Has Trouble Starting After I Get Gas, It Stales And Shuts Off. I...
Asked by
ojayo181
2005
CHEVROLET COBALT
2005 Chevrolet Cobalt Engine Stalled
While Driving, Rattling Noise Started Coming Out Of Engine Area Then White Smoke. Pulled To The Side Then Car Stalled. Tried Restarting....
Asked by
brokencar15
1 ANSWER
2005
CHEVROLET COBALT
Engine Sputters Out
It First Started When I Turned The Car On. As I Turned The Key, It Took A Few Turns For The Car To Start. Then The Car Hesitated When I...
Asked by
kornaj201
2005
CHEVROLET COBALT
VIEW MORE
SPONSORED LINKS
How to Clear a Check Engine?
What to Do When a Check Engine Light?
How to Read Codes Chevrolet
Online car repair manuals
