Engine stall on right turns.
85,000 MILES
IVETTESCHOOL
This is the 1 ton 3500, 15 passenger van. HISTORY: Engine recently swapped. Original manifold used to allow new engine to match, used original hang on parts, starts easily, runs smooth. ISSUE: Engine stalls when making right hand turn. Only occurs when traveling above 15 mph. Immediately recovers when steering is straightened, and left off throtle. Dash lights do not falter. The stabilitrak light (lower left dash) and sometimes the check engine will "Flash" when stall occurs. *Failed to start once, seemed to not be getting fuel and did not have pressure on the test valve on the top of the engine. Pushed van to gain access to check fuel pump and the van started.*
Apr 27, 2013 at 12:38 AM
HMAC300
  • 48,601 POSTS
the test valve you checked may have been the evap canister purge so would not have pressure. check fuelpressure and scan for codes but also do a freeze frame. you may need an adapter for fuel
Apr 27, 2013 at 12:43 AM
IVETTESCHOOL
Thank you. Yes, after another look I believe you are correct regarding the valve. I will follow your advice and have the fuel pressure checked along with that freeze frame on the system. I'll post another reply once I've taken are of the issue.
Apr 27, 2013 at 3:23 AM
