Engine stall intermittently at low speeds?
150,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
KHALIDDVD
  • 56 POSTS
Engine stall intermittently at low speeds. Signals cross-road bumps....etc
Not at all sometimes
Aug 14, 2024 at 6:26 PM
  • 55,721 POSTS
This is common when the engine has a vacuum leak or the throttle body needs to be serviced, here are 2 guides to help a us fix it. Can I ask if the check engine light is on?
https://www.2carpros.com/articles/stall-at-idle
and this guide can help you service the throttle body if you have not had it done with diagrams below to show you how on your car.
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Aug 15, 2024 at 3:40 AM
KHALIDDVD
  • 56 POSTS
No check engine light.
Aug 16, 2024 at 8:53 PM
  • 55,721 POSTS
We are going to need more information if you want help. So, does the engine light come on with the key when the engine is not running?
Aug 17, 2024 at 1:42 AM
KHALIDDVD
  • 56 POSTS
No, but we had computer scanning and dtc clearing.
Aug 17, 2024 at 6:00 PM
  • 55,721 POSTS
Were there any DTC's? Do you notice anything else that is not working? The first thing i would do it check all of the fuses, here is a guide to help:
Also, please follow the guides in the first response to help with the stalling. Check the fuses with the ignition system on. Check out the images (below). Let us know how it goes.
Aug 19, 2024 at 2:11 AM
