Engine sputters out
190,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
KORNAJ201
It first started when I turned the car on. As I turned the key, it took a few turns for the car to start. Then the car hesitated when I first push the accelerator pedal before it would drive normally. The heat intensity blowing from the vents would fluctuate as I would drive. I drove for about 2 miles and pulled in a parking lot. As I slowly approached the stall, the engine just died out. I put the car in park and tried to start it again. It took a few turns, but the car started up. There are no warning lights on to indicate a problem. What would cause this and is it going to be a continuing problem?
Dec 27, 2015 at 11:22 AM
HMAC300
  • 48,601 POSTS
clean throttle plate on both sides and iac hole with choke cleaner.if it continues check fuel pressure with a gauge auto parts rent it.
Dec 27, 2015 at 10:50 PM
KORNAJ201
What is the iac hole?
Dec 29, 2015 at 8:38 PM
HMAC300
  • 48,601 POSTS
idle air control it's aoblong hole in throttle body you'll see it right away
Dec 29, 2015 at 11:07 PM
